F 150 FB anlernen
Rene13051
F 150 FB anlernen
Beitrag von Rene13051 »
Sehr geehrte Forums Gemeinde,
suche leicht verständlichen Tipp zum anlernen einer 3 Knopf Fernbedienung für einen F 150 Bj. ca. 2001 - 2005
Vielen lieben Dank im vorraus.
Google Such Zeit: 0,003 Sek:
Instructions
1
Enter your Ford vehicle and close the door.
2
Slide the ignition key attached to the Ford key fob into the ignition.
Sponsored Links
System Check Removal
Remove System Check Instr. How to remove System Check.
www.wiki-security.com
3
Turn the key on and off eight times (do not start the car), leaving the key in the "On" position after the eighth turn. The doors of your Ford will lock and unlock to show that the vehicle is in programming mode.
4
Press one of the key fob buttons within 20 seconds to program the key fob. The doors of the vehicle will lock. When they do, hit the unlock button to verify that the key fob is programmed.
5
Remove the key from the ignition and repeat the procedure for each Ford key fob you need to program.
Read more: http://www.ehow.com/how_6199609_program ... z2iA5dW1tu
Rene13051
Danke und sorry dass ich mal nicht an Google gedacht habe ...
