Item #91670 - New
1987-90 Ford Bronco ll
1986-00 Ford Ranger<BR>1991-00 Ford Explorer
The Shiftster* is designed as a painless bolt-on application to convert your tired old BorgWarner transfer case from electric to manual. There is NO major modification, NO removal of the transfer case or transmission. In our experience, The Shiftster can be removed and re-installed in just about 10 minutes.
Just reach under your drivers floor pan, pull up on the spring loaded lock pin and turn the handle to whatever gear range you desire---2 High, 4 High or 4 Low. All of these ranges are available and the Shiftster securely keeps your t-case in the one that you select. And it takes only seconds.
