Expedition/Navigator: Felgen und Reifen
Wer liefert was?
euroflyer
Beitrag von euroflyer »
Hi, das habe ich aus dem Handbuch für den Expedition kopiert:
SNOW TIRES AND CHAINS
Snow tires must be the same size and grade as the tires you
currently have on your vehicle.
The tires on your vehicle have all weather treads to provide traction in
rain and snow. However, in some climates, you may need to use snow
tires and chains. If you need to use chains, it is recommended that steel
wheels (of the same size and specifications) be used, as chains may chip
aluminum wheels.
Follow these guidelines when using snow tires and chains:
• Use only cable type chains or chains offered by Ford as an accessory
or equivalent. Other conventional link type chains may contact and
cause damage to the vehicle’s wheel house and/or body.
• Do not install chains on the front wheels. Chains on the front wheels
may interfere with suspension components.
• Chains are not recommended for use on the P275/55R20 tire.
• Install chains securely, verifying that the chains do not touch any
wiring, brake lines or fuel lines.
• Drive cautiously. If you hear the chains rub or bang against your
vehicle, stop and re-tighten the chains. If this does not work, remove
the chains to prevent damage to your vehicle.
• If possible, avoid fully loading your vehicle.
• Remove the tire chains when they are no longer needed. Do not use
tire chains on dry roads.
• The suspension insulation and bumpers will help prevent vehicle
damage. Do not remove these components from your vehicle when
using snow tires and chains.
• Do not exceed 30 mph (48 km/h) with tire chains on your vehicle
Demnach sollte man mit den R20 Reifen also gar keine Ketten fahren?!
unterwegs mit
2007 Ford Expedition 4x4 Limited, 5.4l V8, 305 PS
built in Wayne, Michigan, US
VIN 1FMFU.....LA37298
jack bauer
Beitrag von jack bauer »
Danke, sowas wollte ich wissen. Das sind doch mal Fakten :-)
Beste Grüße aus Bayern!
Rudi
jack bauer
Hallo Profis!
Bin immer noch auf der Suche nach geeigneten Gummis für den Winter :-)
Wie ja im UserGuide steht, dürfen auf den 20 Zöllern keine Ketten montiert werden.
Hat jemand eine Idee wo man die Serien Stahlfelge herbekommen kann? Die ist ja auch als Reserverad unter dem Wagen...
Rudi
Nur nochmal zur Info:
Bei neuen Felgen musst du die TPM-Sensoren auch ummontieren.
Auf dem Reserverad ist kein Sensor vorhanden. Also leuchtet bei dessen Verwendung die Reifendruck-Kontrolle!
Aber das Thema hatten wir ja schon ....
jack bauer
... schon klar. Ist das Umbauen denn ein grosser Aufwand so dass sich ein separater Satz Sensoren lohnen würde?
Rudi
homerbundy
Beitrag von homerbundy »
Die Sensoren sind mit Stahlbändern an der Felge montiert. Für die 18" Felgen braucht man eigene Montagesätze.
Die Sensoren findest du u.a. hier.
Den Montagesatz für die 18" Felgen hier.
Neue Sensoren müssen programmiert werden. Das dürfte auch wieder Geld kosten, abgesehen davon, dass man erstmal einen Ford-Betrieb finden muss, der weiß, wie sowas funktioniert.
Die Sensoren sind übrigens zusätzlich zum Stahlband noch geklebt.
Als günstigen Ersatz für die Stahlbänder kann man auch das Stahlband von der Rolle für Achsmanschetten verwenden. Festkleben kann man die Sensoren mit Spiegelklebeband.
Meine Reifenwerkstatt hatte mir ja auch mal so ein Stahlband abgerissen und es dann zu meiner Zufriedenheit mit Achsmanschetten-Stahlband in Ordnung gebracht.
Grüße,
Harald
jack bauer
... Danke!!
Kann ich denn auch ohne TPMS leben? Eigentlich schon.
Kann man die dann sicher kommende Fehlermeldung abstellen?
Rudi
nur jedes mal wegdrücken möcht ich wetten
Auf den Fahrbetrieb hat das Fahren ohne Sensoren keine Auswirkungen.
Die Meldung ist halt nur nervig. Genau wie die "fuel low"-Meldung.
Beim Explorer geht die Meldung jedenfalls nicht weg.
Und grundsätzlich abstellen kann man sie auch nicht.
Danach haben schon Dutzende anderer im amerikanischen Forum gefragt und sich geärgert.
Lass doch mal an der Tankstelle etwas Luft aus einem Reifen und schau dir an, welche Meldung erscheint und ob du sie kurzzeitig abschalten kannst. Ich bin allerdings sicher, dass sie beim nächsten Motorstart wieder da ist.
Ansonsten frag mal deinen Reifenhändler, ob er dieses Stahlband von der Rolle hat mit den passenden Spannern. Mit solchem Band werden auch Verkehrszeichen an den Laternen befestigt. Vielleicht kann er das ummontieren.
jack bauer
wie wäre das, wenn ich gebrauchte Felgen aus USA kaufen würde. Dann müssten die Sensoren doch drauf sein - oder??
Rudi
Wenn dann stehts dabei
Big-Papa-Charly
Beitrag von Big-Papa-Charly »
DerChef hat geschrieben:Ansonsten frag mal deinen Reifenhändler, ob er dieses Stahlband von der Rolle hat mit den passenden Spannern. Mit solchem Band werden auch Verkehrszeichen an den Laternen befestigt. Vielleicht kann er das ummontieren.
Bandimexband, Knoten und Spannwerkzeug könnt Ihr bei mir beziehen.
Beste Grüße
Charly
95' XPII OHV
96' XPII V8 (RWD)
Ich meine, mal irgendwo gelesen zu haben, dass bei anderer Radgröße die Sensoren neu programmiert werden.
Kann mir aber den Sinn nicht erklären, da es ja lediglich um Luftdruck geht.
jack bauer
sollte der BC über die Sensoren noch weitere Infos bekommen?
Rudi
